Results 1 to 10 of 13
Thread: Just want to publicly thank Chris @ Circle-D
    May 2007
    Chris @ Circle-D did me a huge favor the Friday before the SAR event. I burned up the trans on the dyno the Thursday before and he built me a new converter and had the tranny shop replace the clutches in the tranny that friday (same day turn around). When I got it all back together, the converter was having some major issues (locking up as soon as the truck started rolling), and prevented me from participating in the SAR festivities. I refered to the truck/tranny/converter as being a "piece of sh*t" in another post on this website. Well, long story short the problem was not in the converter, and had nothing to do with anything Circle-D did. The problem ended up being a stuck lock-up solenoid in the tranny (not a typical problem, and rarely replaced) as a result of the trash from the burned up clutches. Its been replaced, and all is well. Thanks Chris.
    It's always a good big accomplishment to get such a big build running. So congratulations on that!
    However, you're already talking bs and the truck is on jack stands, lol.
    Get it on the track, run some respectable times, then say "to all the haterz" because that vid is weak lol.
    You got a long ways to go to compete with the turbos!
    Quote Originally Posted by 2boosted View Post
    Sorry dude....what I meant is that you are full of shit. Your supercharged turd wont ever make it to the 8's and your wasting energies as Casey did.
    Go turbo and be done with it.
    I here that guy is a pretty decent fella.
    Feb 2005
    Austin, Texas
    A lot of guys on pt are loving his converters, if/when I ever need another one Ill definitely be going by his shop to get one
    casey23 Guest
    yo
    Fixed huh ??? Did you ebay that Procharger put a rear mount on there ?? That will fix all your troubles
    May 2007
    Quote Originally Posted by casey23 View Post
    Ha, yea but then I'll have to deal with the fire dept. I'll stick with slipping belts, no low end and busted acc. brackets. If I can ever get the truck back working as good as it was it ought to run a decent number. It picked up a little power on the dyno.
    southside VA
    casey come on, rearmounts dont work that well lol
    j/k buddy
    casey23 Guest
    Quote Originally Posted by LsxCody View Post
    j/k buddy
    I know man... Rear mounts really dont work well with only two gears ..
    Feb 2005
    Austin, Texas
    They still run mid 10s and trap just shy of 140 in the quarter
    southside VA
    when u get it right im sure itll be nasty, hit me up sometime
    Oct 2007
    Bandera, TX
    ya, love my Circle D verter. working great. Chris is an awesome guy, cant say enough about his service and product. How do I get one of those Circle D shirts?
    good luck on getting the truck going and your goals. look foreward to seeing some times out of that beast.
