Thread: L59 32lb injectors...
    What is the horsepower limit on a set of stock 32lb injectors on my 2005 VIN-Z L59 on 93 Octane... I guess what i'm asking is can i run my 5.3 single front mount at about 7 or 8psi and be ok if i upgrade to the 255lph walbro? Or do i STILL need the 42's?
    -2005 1500 Z71 ECSB 6.0 swap, Cooks Racing 4L80E, NP261HD, Carolina Driveline 5" shaft, CST Tie-Rods, front mount 76mm, Livernois hot pipes, Circle-D 258mm (~3500), Mallory 2-step, 100 Dry shot, 750CC RC Eng. Inj, Nelson Tuned, 4.10's, all through a STOCK 10-bolt
    My money would be on that the FF injectors will not be enough. You do not wanna run short of fuel on a FI motor...or any motor for that reason. Detonation is not good. Go ahead and get 42lbs at least. 8.1L Marine injectors (44 lb/hr) are 100% plug and play.
    Augusta, Ks
    Id go ahead and spend the money on some 60lb injectors. Ull want more boost later on.
    2004 Buell XB12s
    Broken Bow, OK
    Buy bigger and sell me your FFs.
