Thread: Z71 Gear swap
    Z71 Gear swap
    I have a 2003 Avalanche Z71 with 373 gears and I am thinking of going to 410. Is there any threads on swapping the gears for 4X4 applications?
    Dec 2009
    Houston, TX
    Quote Originally Posted by Eagle1 View Post
    That's a lot of time/expense/effort for so little change in gear ratio, especially on two axles. What size tires are you running or ever planning to run, and do you tow a lot and/or drive a lot of highway miles?
    2006 Z71 Tahoe - Silver Birch Metallic
    GO: Wheatley 93 street tune, TR220-112 cam, PAC 1218 springs, Comp rocker trunions, U/D pulley, LS2 timing chain, JBA headers, cat delete, Magnaflow catback, AEM CAI, 180º stat, ported TB, Circle D 3200, TransGo HD2, billet servos, Tru-Cool 40K, LS6 valley cover, and many more...
    SHOW: Ford keys, 2" spacers, Bilstein 5100, SS cluster, HIDs, LEDs, and many more...
    Quote Originally Posted by Z'06 View Post
    Only 33's. Thanks for the input. I guess it really isn't worth the change. I see quite a few people go from 373's to 410's and was thinking the same but I guess not now.
    im running a metric tire tire which equals a little less than a 34 and i just put 456 in it and i love it. runs at 2100rpms at around 70.
    Mar 2007
    Newark, Delaware
    With 33's, I think it would be worth the hassle to swap in 4.10's or 4.30's. Plus, if your rear end is stock then you can upgrade the carrier with one that can actually take some abuse.
    +1 on that i just cracked my carrier!!! upgrade that pos g80
