Thread: Vibration Update
    I keep updating you guys becuase i know a drivetrain vibe can be a pita.
    Well, Joe and I (well joe did) pull the pinion yoke last night and replaced it with pretty much a brand new one.
    As soon as the ujoint caps set into place on the yoke seats, i knew it was much better, the slack was eliminated, the was no side to side movement between the yoke and snap rings. I guess when the shaft was ripped out, it made the yoke widen a little bit.
    I took it for a test drive right after and the hmmm/vibration was gone
    I got it up to about 90mph (wow was it nice to go that fast again), and i didn't notice any vibes from the shaft.
    I do however have another vibration, but this one is kind of random and is in the seat and steering wheel, i'm guessing it's the old farm tires that are as hard as a tricycle tire, doh. i'm going with the Kuhmo tires, i've heard good things about them and plus look how cheap they are.
    i hope this experience helps others in tracking down thier vibe problems.
    btw, when the shaft was off, joe felt the movement of the bearings and ring and pinion, and he didn't like the way it felt, so we're going to tear it down and replace the bearing and stuff. he said it felt like the bearing were binding or rough, while turning the yoke.
    later,
    allen
    San Marcos Texas
    What about the "MAGIC" aluminum driveshaft with no vibrations!! Did you give up on that?
    Florida
    happy to hear it...and it didnt even take the aluminum d/s to fix it go figure....btw i hope you mean NO vibration as opposed to a small one at high speeds.(i bet theres still one there...maybe around 120mph )
    brandon
    485rwhp/440rwtq SAE
    Jasper, Ga.
    If his truck will run 255 with the help of Edit I am sure 120 should be a safe test run after tires I hope.
    1999 Silverado 1500 Ext. cab Red 2/4 hotchkis drop & swaybars, bilstein stocks, AR626 & 404 Nitto's, Yank converter, ASM headers, ASP underdrive pulley, Taylor wires , free mods VCN 2000, Nelson Performance tuning
    2002 Red WS6 M6; Flow master K&N
