Results 1 to 10 of 13
Thread: 4WD not activating
    Sep 2009
    Florida
    4WD not activating
    My buddy has a 99 ecsb 5.3 AT. when he puts it in 4WD it does nothing. Is it in the switch a relay or what?
    Mike
    07 Avalanche LT1 w/5.3 We call her Ava
    Sep 2009
    Florida
    it is the push button
    Mike
    Pittsburgh, PA
    do the light flash? check the vaccum solonid on the firewall. bypass it the front diff should engage then presh button to engage transfer case
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Sep 2009
    Florida
    Is it vacuum? I don't know it's my buddies truck and I havn't even looked at it.
    Mike
    Encoder motor. I promise.
    Sep 2009
    Florida
    What the hell is that?
    Mike
    The thingy-ma-bob that bolts to the transfer case...which makes the 4WD happen. (In Layman's terms. I could get technical, but that would spawn more questions.)
    I have never known for a 4WD dash switch to go out. Its always the encoder motor. TRUST ME. Don't ask questions. Just replace it.
    Pittsburgh, PA
    i replaced mine and it wasnt the issue. mine was the solonoid on the firewall.
    412 Motorsports
    Sep 2009
    Florida
    ok friend I will
    Mike
    Wasilla, AK
    Nothing is vacuum operated on a 99 ECSB with 5.3. Only on T-series blazers & pickups.
    The 99-02 had very high failure rates on the switches. If he can scan the truck and give us a code, we will be able to say switch or encoder motor. Otherwise it's just a guess.
    When he pushes the switch button for 4x4, what does the switch(lights) do?
