Page 1 of 17 1 2 3 11 ... LastLast
Results 1 to 10 of 162
Thread: Time to get started 4.8 to 5.3
    Feb 2009
    Quality KY.
    OK Time to get started on this bad boy. Have never pulled an motor on this body still 2002. Better to pull the motor and trans in one piece or apart. Pulling the the 4.8 and the 4L60e and Putting in a 5.3 and a 4L80e. The 5.3 is getting a Magna Charger also. Got a lot of work to do.
    If it was me, I'd take the tranny off first. Makes things more manageable.
    Damn man--you've got some work ahead of you. But it is FUN work cause you are gunna have all kinds of it when you get finished.
    Feb 2009
    Quality KY.
    For sure it will be a lot of work. But in the long run I think I will be much happier with the truck. And I know it will pull a lot better. I have pulled a lot of motors but never on this body. I have a cherry picker and I hope all the tools needed to do the job. I like to pull all in one lick so I do not have to lift the trans in under the truck. But was not sure it could be done with just one guy. Never can get any help.
    Damn man, that sucks that nobody will help ya. Its always more fun when you have a friend to help.
    But if you've got only yourself, then I am sure you can pull it all out at once. I have personally have not done it, but I have heard about others who have.
    You will need to get it in the air a pretty good ways before you can tilt the motor and tranny enough to get the tailhousing to not scrape the ground and for the oil pan to clear the crossmember. But then you have to watch out for the firewall...
    Do you not have a tranny jack? They are worth their weight in gold...
    Remind me on monday I can the full GM procedure for ya if ya'd like
    Feb 2009
    Quality KY.
    Quote Originally Posted by sleeper1500 View Post
    That would be cool THANKS. No trans jack. I am more worried about going back in than out as that 4L80e is so heavy. I built me 66 with no help so I am used to it. The only thing that kills me is getting hoods off and back on. I have floor jacks and air tools witch helps a lot. I just move kind of slow with my bad leg. Just take my time and think before I grab. Thanks Guys
    The Garage
    You may have seen this already but just in case you didn't, take a look
    http://www.ls1truck.com/forums/front...rans-swap.html
    The only parts that would frustrate me are the crossmember and the wiring. Good luck bro!
    Feb 2009
    Quality KY.
    Quote Originally Posted by jetmech View Post
    THANKS Just read it. Best I can tell all I am missing is one plug for the other speed sensor. There was a link on here to a place that sold them but can not find it.
    Augusta, Ks
    2004 Buell XB12s
    Gramercy
    coming out with the motor is easy. going back in will be crazy lol. i had to pull my motor/tranny by myself in my OBS an im 250lbs an i had hell keeping my engine lift from tipping forward when the tail shaft got hung up. im going back with a long block then going from underneath with the tranny an finish everything else with the engine in the truck. i never have help anymore thanks to me being on ahift work an all my other friend being on straight days.
    isnt there a peice that turns your floor jack into a tranny jack? or am i just dreaming? if not then make one if you have a welding machine
    2008 GMC CCSB 6.2/6L80e swap
