Thread: new form ky
    Butler Ky
    new form ky
    I have NX kit that has 1 bottle ran through it.
    I bought the kit with intensions of spraying the turbo set up, but i would rather just build a 370 and turn the wick up.
    The kit is Wet NX single shark nozzle kit that includes
    Stage 6 nitrous niod
    Stage 6 fuel noid
    Purge kit is their stage 1 nitrous noid
    15 feet of nitrous line
    Nitrous outlet nitrous filter
    Fuel pressure safety switch
    Black -4 an fuel line with fittings for the FPS switch
    wot switch
    NX window switch
    Bottleheater is their $289.41 automatic kit it will automatically maintain temp
    10lb Bottle
    Custom bracket to hold fuel nitrous and purge noids, it mounts on top of the throttle body and works with the engine cover and for a very clean and professional install.
    It will also come with 2 relays, black -4 an fuel line with fittings for the FPS switch, a wiring harness for the bottle heater kit, lot of fuel/nitrous jets and NX book with all the wiring diagrams and such.
    550.00 OBO
    Thanks for Looking
    -Nate[IMG][/IMG]
    76mm Front Mount, Yank PT3200, 6.0, Built 80E, Isky 215/215, Devils Own, Nitrous Express
    Butler Ky
    can someone edit the
    New form ky
    -Nate
    you from bulter county? be interested in some 18x8.5" wheels powdercoated? jw
    Psalms 144:1
    Si vis pacem, para bellum
    Butler Ky
    Im in Campbell County. Sorry not lookin for any wheels, i need to finish my 370.
    -Nate
