Results 1 to 8 of 8
Thread: 2.25" or 2.5" dual exhaust
    hot & windy
    2.25" or 2.5" dual exit pipes
    i'm planning on adding tail pipes to the truck and am considering 2.25" and 2.5" piping. i know it's a small difference, but i'm having trouble deciding which size to get.
    when i had the 4.3, i was running a single 3" pipe from the y-pipe to a single in, dual out MellowTone muffler (similar to a FlowMaster50HD) and no exit pipes.
    now that i've swapped in the 5.3, i don't know what it is - shorter stroke/smaller cylinders, more cylinders making more constant flow, or what - but it's just a lot smoother and a little quieter (unless i'm getting on it). now i want to add tail pipes to beef it up a little (and get a little more low-end torque back). the muffler has dual 2.5" outs, and i want a little more growl than a hollow-mustangy-sounding gurgle. i'll probably use some 3.5"x15-18" tips to deepen it up a little, but i just want y'all's opinions on which to go with.
    just some application notes about the truck:
    -it's my DD, so i don't need to lose any more fuel economy (if that would even be a factor)
    -engine is a stock 5.3 with a tune & an up-and-coming CAI
    -using stock manifolds, cats, & y-pipe with 3" pipe to the muffler
    -it's 4x4 (with a 265/75-16 spare, soon to be a 285/75-16 when i get a new set of tires)
    -i plan on a mild cam swap on down the road: something to bump the low & mid range
    -since it ain't gonna be a HP monster, the flow differences between the different sizes is negligible, right?
    thanks for the help
    99 Sierra - 5.3 / 5spd
    Spiro, Oklahoma
    I started with 2.25" duals with no X,H or any kind of balance pipe and loved it, for some reason I switched to 2.5" with an H-pipe and hated it, I couldn't believe how much low end I lost just from uping the pipe size.The responsiveness sucked and it sounded like something only a hillbilly with down syndrome would like. I switched back to my original setup and never looked back. I ran 2.25" on the 5.7L TBI that came in the truck with no complaints and will probably run 2.25" when I build a 6.0L.
    EDIT: Sorry, just re-read your post and realized you were refering to a dual outlet muffler and not dual exhaust, in which case I have no clue. Though I doubt it would make a huge difference since its after the muffler.
    hot & windy
    thanks for the feedback. i edited the title to clear that up a little.
    if i was doing a full setup, i'd go with 2.25" because it ain't any kind of exhaust-breathing dragon or anything... just a stock~ish 5.3
    Dual 2.5" is gunna be too much for the stock-ish 5.3L. I am gunna say to roll with the 3" to the muffler and run 2.25" to the tailpipes.
    Stillwater, Ok
    found this before, how relavant is up to what you read into it
    2003 SLT Yukon, KMC SS 20's, Nitto 420, Flowmaster exhaust, Eibach 2/3 drop, HID's, AEM CAI , Custom Flames from Godspeed Customs, Corvette servo
    hot & windy
    nice chart... is that based on crank HP or wheel HP? that would make a huge difference
    so far it's looking like i'm going with 2.25" and i reckon once the cam's in i'll re-evaluate how it's holding up (probably be fine).
    does anybody have anything similar to this that i could see/hear?
    Stillwater, Ok
    oh I'm sure it's crank. For sound, 2.5" dual pipe will sound best, but it's up to you, power, or sound.
    hot & windy
    well the way i see it is that the 2.5" might be too big & give me that hollow gurgley sound, which i don't want. since, according to that chart, the 2.25" would flow better/have better pressure for my motor & it'll give a little more definition to my exhaust note, the smaller pipe sounds like the better option.
    now i'm to the point of trying to find somebody with a similar setup that i can hear a video of
