Results 1 to 10 of 11
Thread: Shift Kit?
    Missoula,Montana
    Shift Kit?
    Thinking of installing a shift kit in my truck.What are the advantages,disadvantages of a shift kit.I already have the Billet Servo's installed.Thanks.
    '00 1/2 TON ECSB 5.3L 4L60E
    K&N Filter,Gibson Exhaust,Superchips Programmer,Billet Servos,'03+ Taillights,White Door Handles,Carbon Metallic Grille Emblem,6000K HID'S
    Okeechobee, Fl
    The crispness of the shift and the longevity it gives ur tranny are the up sides.
    Not sure of anything bad...
    49 Ford F1
    Jul 2009
    I would go with the TransGo HD2 Kit. Want that and servos for mine before i abuse it anymore.
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    Quote Originally Posted by DUALLS View Post
    It will give you better performance and shifts out of the 60e--plus help it live a little longer. The HD-2 and Superior kits are pretty good...
    Jul 2009
    Well which would you go with then?
    06 2wd
    Missoula,Montana
    So we should go with the Transgo HD2 kit?This my daily driver.
    Yeah, HD-2 is a good kit to use. Pair that up with some Corvette servos and you'll be good!
    Missoula,Montana
    Now will I have to mess with my line pressures? I only have a Programmer right now,but all the tranny settings are set to stock.
    Jul 2009
    You can but don't have to. Shouldn't have to increase them very much.
    06 2wd
    I would keep it all stock in the tune. Do not install any washers in the 2nd accumulator from the kit. If the tranny doesn't shift firm enough for you after that, then you can bump things up in the tune.
