Thread: 1996 gmc suburban K1500
    I am looking into doing the lq9 or lq4 swap. with a 4l80e trans. I have a laundry list of parts and was wondering if anyone could fill in the parts i am missing or any recommended suppliers.
    -lq9 or lq4 motor(block, heads, intake manifold, fuel rail and fuel injectors)
    -4l80e trans
    -tranfer case should bolt up correct? i have the push button selector for 4wd.
    -Any recommended rear ends.
    -Painless wiring harness or DIY
    -Motor Mounts? I dont know who exactly
    There is alot of information on this forum but to defend myself from getting flamed i am just trying to make sure i do this right. My truck is also lifted if that makes a difference
    Dec 2004
    San Antonio, TX Area
    You can buy the engine from here.
    High Perfomance Salvage, inc.
    They come complete.
    I can't help you with the transfer case, some one will though.
    The factory rear end should hold up no problem.
    You can do the harness yourself or get one from here: Nelson Performance - Products
    Get your PCM tuned by them also.
    Here is where I got mine.
    CAR SHOP C/S2349 LS1 LS6 CONVERSION MOTOR MOUNTS ADAPTER PLATES $45.95 BUY ONLINE
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Monett Mo
    The transfer will bolt up but only if you have a 4l80 or a 5 speed already. Otherwise you will have to change the input shaft in your transfer case.
    1992 rcsb k1500 lq4 4l80 swap done.If anyone has questions feel free email as I'm not on here very often. bobby_seitz@yahoo.com
