Results 1 to 10 of 11
Thread: Drive shaft which is better 2 piece or 1 piece?
    S.A. Texas
    Which one is better and will a 1pc hold up to the 400+hp/Tq I am making. I also run slicks at the track so not looking to wipe everything out. The one i am looking at is a 1 pc 4in aluminum. Thanks gang.
    Plainfield, IL
    I was always told the 2 piece ones are better for lifted vehicles because of the ability to moderate the angle between trans and rear.
    As far as racing goes, i would assume a 1 piece would be stronger/less rotating mass. Most race cars use a carbon fiber or aluminum 1 piece, so there must be a reason.
    You ARE extended cab so that is a pretty long 1 piece, might want to talk to the company making the shaft to see what they recommend.
    S.A. Texas
    That is what i always thought. I have a drive line vibration that i am looking to get rid of. Seems like the one piece would be better for that but I dont want to toast the trans and rearend if the driveshaft lets go when i launch or going 120+
    stay with the factory 2 pc. i used a one pc. and broke it, it was alluminum at WOT the shaft would flex, so after flexing alot lol it twisted and broke.. i then went back to my 2 pc. and ran ever since until i swapped the drivetrain
    by the way the 2 pc got me my 11.8 pass
    Simple: 408 on steroids!
    single digits coming soon!
    S.A. Texas
    Gotcha guys Thanks
    Jan 2005
    Humble/Houston TX
    yep. 2 piece. im still on my factory 2 piece no problems.
    old mod list: H/C/I/N/E/G 408
    hey mark what speeds you getting vibration at? might think about pulling the drive shaft with carrier bearing and getting the whole thing rebalanced ?
    S.A. Texas
    about 70ish mph, I relocated the carrier but i guess i need to check the pinion angle again. it should be -3* right?
    Plainfield, IL
    Check pinion angle if you're lowered. Check carrier bearing/u joints for play
    how low are ya, IIRC its like -3 to -6
    when i welded my bracket backet back in i adjusted for the pinion angle though
