I have a 99 silverado with a 5.3. Tryin to find a rear diff that will take some abuse. Have had the truck 2 years and broke the spider gears twice and broke some teeth off the ring gear a few months ago. Any suggestions?
99 Siverado 5.3L
Airaid Cold Air Intake
True Duels with X-pipe
Shorty Headers
Diablosport Tuner
And is still way to slow!!!
get a dana 60, crazy strong
is this a stick shift truck? I'm really surprised you are breaking the rear.
01 ecsb 5.3 4x4 z71
Avalanche 17s and a pant load of miles
61 Corvette
350, 4 speed, 4.56's
32 Ford 4 door sedan
keeping it "stockish"
TRUTRAC all the way!!!!! You won't be dissapointed![]()
Mike...I hope bad things will happen to you.
HAHA. J/K. Maybe.![]()
its a auto. I put a new auburn limited slip in it the second time the spider gears broke. and replaced the ring and pinion with one from Yukon gear. Its 4.10 gears. I broke the teeth right of the ring gear screwing around in the rain. It is on the second trans soon to be third!!
99 Siverado 5.3L
Shorty Headers
Diablosport Tuner
Yeah, typically when the rearend goes, it takes the tranny with it unfortunately.
Make sure to get some strong gears with a good locker.
Do I need to go bigger than the little 8.625in 10 bolt? or can I build that to take some abuse?
99 Siverado 5.3L
Shorty Headers
Diablosport Tuner
the 8 1/2" ten bolt is a really good rear for what is is. and you only have a handfull of mods, maybe 30 hp over stock. and its in a relatively light truck you shouldn't be breaking it. nevermind breaking it over and over again. Maybe the housing is bent. does it wheel hop?
01 ecsb 5.3 4x4 z71
61 Corvette
