Results 1 to 5 of 5
Thread: Scorpion Rocker Arms
    The Garage
    Brand New never used. These are Scorpion's latest configuration which can tolerate stiffer valve spring - up to 400lbs open spring pressure according to Scorpion.
    $350 shipped - OBO
    will ls6 springs work with them?
    2001 Camaro SS conv. R.I.P.
    2005 RCSB: LT offroad Y, G80 3.73, cold air, Zex wet kit 125, 2002 LS6 cam, Nelson Tune, 3400 stall. SOLD
    1978 Monte Carlo: 305cid, LT's, duals, 3.73, 1.6 rockers, future LSX
    The Garage
    Quote Originally Posted by gregsss View Post
    They should, you can run these with patriot dual golds if you want
    The Garage
    still up for grabs
    Ponca City
    You need these greg! The springs should so long as these dont put the lift of your cam past what the ls6 springs will hold. May have to put the other set you have in.
    Slowest in Oklahoma...
