Results 1 to 10 of 17
Thread: have a question on a camshafts
    San Antonio/Laredo
    Question have a question on a camshafts
    ok guys so i went to get my heads P&P and i was talking to the guy i told him i was gonna go with a asa cam and he says that cam is too small for my truck this truck is a 00 ext. cab silverado, he says i should go with a Mega Death or a T-Rex cam i like how they idle but im not sure if it would work well in my truck its gonna get a 6.0 LQ4 and it is a daily driver i want something with more torque and a choppy idle and opinons ? i also did see some nice cams from vincihi performance any one have there cams?
    Thanks
    Ross
    get a custom grind cam
    Sep 2006
    THE 405
    ^^^why?
    Why not try something proven?
    2007 RCSB|DTR81 built LSx 3xx|PRC|NX|BOGART|MSD|QUICKFUEL 950 E85|4L80|FTI Converters|Smith RaceCraft|Racepak
    midweststreetcars.com
    San Antonio/Laredo
    what proven cam would you sugg? im planning to keep the engine N/A
    Quote Originally Posted by parker View Post
    ^^^why?
    cause it will dominate a proven cam,cause its spect specifically for your application.
    talk to a meli or allen from nelson performance,,they can get you a custom grind cam.
    ive been through 3 cams,,,u see the specs in my sig thats the last cam im gonna buy...
    Sep 2006
    THE 405
    So you're tellin me that your 219/223 .603 cam is going to dominate any other cam ever put in a 4.8? Why? Do you know? In what way is going to "dominate"?
    The megadeath and the trex may be a little big for the stock 5.3...for some. I run a G5x3 which is a 236/240 .615 112lsa in mine. But I also run higher compression with 4.56 gears and 3800-4000 stall
    for a 6.0 I've read lots of good reviews on the trex cam. Pulls like no other up top.
    I'm not tryin to steer you away from a custom grind because I'm sure they may have a slight advantage. But they seem to be kind of the "fad" for the moment so that when asked "hey man what cam you runnin in that thing?" you can proudly say "oh it's a custom grind by bumpstick Willie". People ran off the shelf cams for years with great results.
    In the end, if you can save a $100 or so by finding a used cam in the classifieds , do some research on it and if you like what you see, buy it. With that being sad, my cam is for sale
    San Antonio/Laredo
    Thanks parker how much for the cam do u got any vids let me know its my bday and my girl said she would get me something for my truck
    u just need to get a custom grind yourself,,u can ask anyone whats the best cam,,your answer will be custom grind.
    i know theres proven off the shelf cams,,but why be like everyone else and get one,,when u can get a better cam to how u want it to perform and idle.
    btw why u selling your cam?lol
    futbux just go custom grind,,save yourself multiple cam swaps
    S.A. Texas
    I think the biggest advantage of a custom grind cam it that most people dont REALLY know what they need. That being said i made i made pretty good power with a off the shelf cam with my turbo set up. I will be getting a custom grind cam in the near future. So either way. But the mega death is too big for your truck unless you are gonna run a high stall.
    Pick the one u want, then go two sizes smaller! Hah. Seriously. I love this forum and all the extremely intelligent people here. But for a heavy truck with a small motor go a little small on the shaft. Keep in mind who your asking when posting here. Most of us want max power and don't mind sacrifices in drivability. So your going to get suggestions for 240 ish @050 cams with 600 plus lift. But is that best for your daily driver? No. Will it dyno higher? Yes. Will you wish you hadn't? Yes. With that said. No stall. 3.42 or 73,s on a 4.8 look for something 218/224. In the 550 range with 114 or 115. You'll get torque and drivability with very minimal compromises.
    2005 crew cab, new crate lq9 with comp 212/218, 558/563 on 115 cam, 80mm t.b. coated long tubes, off road y, flowmaster cat back, dynomax bullet, ngk plugs, msd wires, k&n cold air kit, 4.10 gears, auburn pro lsd, transgo shift kit, nelson drive tune, trailblazer i-6 torque convertor, anzo lamps, ss front bumper, z71 tahoe rear bumper, debadged, kenwood touchscreen with headrest monitors, JL components, coaxials, sub, 5ch amp. bell tech 2/4 drop. 22x10 ss wheels with 285/35/22 bfgs.
