Results 1 to 7 of 7
Thread: gear question
    Oolitic In
    gear question
    i have a 05 4x4 4l60e with 3.42s, does anyone know what a set of 4.10 would put the rpms at 70mph cause gotta drive it everyday on the highway... but still like to play around on the weekends with it
    Plainfield, IL
    What size tires?
    Oolitic In
    rite now its still stock rims with 265/70/17 but want a set of 20 for it soon... If makes a diff has a 220/220 581 lift 113lsa cam and a 3200 stall... but rite now i do drive iton the highway alot but on weekends go out and play with ppl that wouldnt see a truck run that good.... Got vid of me running what thought was an 09 but got told it was a 10 camaro check it out in the racers lounge
    Cromwell, CT
    2300ish
    01 ecsb 5.3 4x4 z71
    Avalanche 17s and a pant load of miles
    61 Corvette
    350, 4 speed, 4.56's
    32 Ford 4 door sedan
    keeping it "stockish"
    Quote Originally Posted by straightaxle View Post
    2300ish
    Yup. At 70 mph--2300-2400ish. 3.23s are a highway gear and stupid for a 4WD truck, IMHO. I would go with AT LEAST 3.73 gears. But remember--the cost of doing a gear swap will double since you have to do BOTH axles. If you do end up doing a gear swap, make sure you get the gears you want cause you do not wanna pay the $$$$ to do a gear swap a 2nd time....
    that ain't no shizz!!!! my 4.88s in my old truck cost out the wahzoo for the parts and install
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
    Plainfield, IL
    what rpm were you turning with those 4.88s chris? I'm thinkin bout 4.56 for my 34's
