Results 1 to 8 of 8
Thread: gmc sierra shift indicator light not working
    Angry gmc sierra shift indicator light not working
    bought the truck. it needed a trans (shift indicator was not working) changed the trans and the range selector switch.everything is ok with the trans still no shift indication or millage does not light up. could it be the cluster? is there somewhere i can check for voltage to this on the cluster? any help would be awesome truck is a 1999 4x4 5.3 4l60e trans
    If no shift indicator OR mileage, then it might be a cluster issue. Try replacing the cluster or have the dealer reprogram it for you. The shift indicator is a part of the wiring harness associated with the 'Prindle switch' on the driver's side of the transmission. If the wiring harness is fine and the cluster is reprogrammed and the issue still exists, then just replace the Prindle Switch. When removing the wires, make sure to heat up the wiring harness plugs with a lighter for about 10 seconds before trying to pull it out. The connectors come from the factory with this sticky sealant stuff that is like glue when it is cold...
    LOL I bought a new switch because i broke the old one off the plugs I guess ya live and learn
    Thanks
    There is no 99 utility with a 5.3 and the 99-02 pick up cluster does not need programmed and in fact cannot be programmed. If it's a truck and the PRNDL sections won't light up at all it needs a new cluster.
    utility ?
    Quote Originally Posted by crazystangg306 View Post
    utility ?
    Tahoe, Yukon, Yukon XL, Suburban, Denali, Escalade....
    the problem is with my sierra
    Just answering your question...
    If there is no PRNDL or odo on a GMT800 then the cluster is at fault. If the gear indicator switch or PCM were at fault the letters would all be there but all would have boxes or none would (dash underneath the letter 03+).
