Thread: Wiring harness Question
    Feb 2009
    Reworking my harness and have a couple questions. The engine is an 02 lq4. Its going in an 86 chevy truck backed by a th400 non lock up transmission. I'm using a 99 wiring harness from a 4.8. Is there any reason why I can't remove all the wires from the harness that have anything to do with the electronic controlled tranny? Does TCC=Torque Converter Control? Do I have to run a vss?
    Cromwell, CT
    I would ask The guy that did/is doing the ECU, I know they can delete alot of the extra BS stuff in the computer for a swap like you are doing
    01 ecsb 5.3 4x4 z71
    Avalanche 17s and a pant load of miles
    61 Corvette
    350, 4 speed, 4.56's
    32 Ford 4 door sedan
    keeping it "stockish"
    Pittsburgh, PA
    the vss is used to control the timing tables. if not youre more then likely be stuck in the idle timing table
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    hot & windy
    you should talk to Jared @ Current Performance Wiring
    99 Sierra - 5.3 / 5spd
