Results 1 to 10 of 26
Thread: Brake Upgrades???with Oem Stuff
    wtby ct
    mornin im planning on putting a set of 24's on my suburban and was wondering if there are any brake upgrades we can do with factory parts.ive seen some posts on the vette stuff but was also wondering if there are any other options??but the vette stuff does look pretty.thanks...VJ
    2001 Suburban 1500 5.3 4x4 Lt
    WHATS DONE SO FAR- CAI, 3inch Cat back with flowmaster,2-3 inch drop,rebuilt trans with hd2 transgo,TB Converter,aftermarket trans cooler,Tinted tail lamps,Street
    Scene grille,hids,punched Cats,20 inch incubus wheels,07 front brake upgrade,clear corners
    WHATS IN THE WORKS- 2005 6.0L swap in the works,long tubes,Z06 cam,ls6 yellow springs,e fans,ported throttle body all to come shortly
    New Orleans
    You can get drilled and slotted rotors and good brake pads. Any other way will cost you lots.
    04 Silverado Ls
    lq4 swap, electric fans, 228r, 243, K&N Cai, LPP, EFILive, FLT, yank 3000, trutrac, 3.90s
    Round Rock, Texas
    Braided steel brake lines. I had to use them because of my lift, but they increased braking power significantly! No more spongy feel on the pedal, too.
    wtby ct
    GREAT NEWS!!should be able to swing that.how about pads whats everyone using??
    Well, you can upgrade the front brakes to the 04 and up caliper/rotors/pads. When GM switched from the 4 wheel disks back to the front disk/rear drum setup, they increased the size of the front brakes. Its all factory and will bolt right up. You can go to Autozone or O'Reilly and get everything there. Just make sure to say its from a 2WD 04 and up truck with the rear drum brakes.
    wtby ct
    OK so order 2wd from an 04 up??
    Yup. But just to be sure, get either 05 or 06 stuff.
    Drilled and slotted rotors. (Waiting for G to see this)
    Broken Bow, OK
    Your suburban will already have the 2 piston calipers in the rear, so like already said get the 05 front brakes and also look into a factory hydroboost set-up from a 2004-up Suburban/Tahoe.
    wichita falls, tx
    i got the drilled and slotted rotors for an 06 and just bought some 06 calipers...direct bolt on and definitely was a noticeable difference
    http://www.ls1truck.com/forums/racer...akes-02-a.html
    Intro Radicalli's
