Results 1 to 10 of 23
Thread: Mustang injectors?
    Nov 2006
    Elk Grove, CA
    Mustang injectors?
    Does anyone know if the injectors from a 95 mustang will fit in an LS1 intake if I have the right connectors? I have an opportunity to get some 30 pounders and would like to know if they are the same diameters...
    30 lb Ford injectors would not even be worth the money to make them work. What vehicle/motor are you wanting bigger injectors?
    Jan 2005
    Humble/Houston TX
    i run ford injectors on my ls1 style intake. they will work with the right connectors spliced into your wiring harness.
    if they are rated at 30 pound on a ford they will push more behind a chevy. i want to say ford runs about 38 psi fuel pressure where chevy pushes 58.
    old mod list: H/C/I/N/E/G 408
    Sep 2006
    THE 405
    lots of people run ford injectors on our trucks. not that expensive to make them work. just get the right connectors. 30# ford injectors are more like 42s for us right?
    2007 RCSB|DTR81 built LSx 3xx|PRC|NX|BOGART|MSD|QUICKFUEL 950 E85|4L80|FTI Converters|Smith RaceCraft|Racepak
    midweststreetcars.com
    Nov 2006
    Elk Grove, CA
    6.0 with cam, LS1 intake, and ported stock heads. My harness is already apart so I do not mind splicing one bit. So they do fit in the smaller LS1 holes?
    Sep 2006
    THE 405
    they will work? you're talkin about the red tops im assuming?
    Nov 2006
    Elk Grove, CA
    Yup that's them
    Sep 2006
    THE 405
    yep yep...do some searchin and find out what adapters you'll need
    Nov 2006
    Elk Grove, CA
    What type of connector is on our truck harnesses anyway? Not EV1 or EV6 right?
