Results 1 to 7 of 7
Thread: newb from the f body world
    Oct 2009
    Whats up everyone. I had a '02 Formula that was stolen last year and I havent replaced it yet. I had an idea of a true street beast, a twin turbo'd 416 c.i. motor in a trans am but I had issues with that so it was all sold. Now I'm looking for a few different options, vettes, cobras, M3s, all in the same price range so who knows what i'll settle with, lol. In the mean time thou, a friend has a 2000 Single cab short bed Silverado with a 5.3 in it. Well hes selling it for real cheap and I figured I will need a tow rig and while its not the prettiest thing, it can get the job done, only issue is he thinks it spun a bearing or 2, but I have an extra LS1 with a bad crank thou. So basically i'm here to see if i can mix the 2 engines and get 1 good running engine, lol. So I'm going to go do some research. Any tips or tricks will be helpful thou.
    -Rich
    Feb 2004
    Western, KY
    the cranks and rods are the same
    4.8 stroke 3.268" bore 3.78" rod length 6.276"
    5.3 Lm7 stroke 3.662" bore 3.78" rod length 6.098"
    5.7 Ls1 stroke 3.662" bore 3.898" rod length 6.098"
    6.0 Lq4 stroke 3.662" bore 4.00" rod length 6.098"
    Feb 2004
    Western, KY
    sorry but welcome to the site forgot to say in the previous post
    Tyler, TX
    welcome to our humble forum. . .yeah, you can knock that 5.3l out lickity split, you could even swap in the ls1
    www.tjc.edu
    Oct 2009
    Thanks for the welcome guys.
    The rods are good on both engines, the crank on the LS1 is bad though. Can I swap the top end from the LS1 to the 5.3?
    welcome to the thunder dome.
    Sep 2006
    THE 405
    Quote Originally Posted by R W B View Post
    Yes. Just be sure to have it balanced. Although the stroke is the same on the 5.3,5.7, and 6.0, the 5.7 rotating assembly is balanced different
    2007 RCSB|DTR81 built LSx 3xx|PRC|NX|BOGART|MSD|QUICKFUEL 950 E85|4L80|FTI Converters|Smith RaceCraft|Racepak
    midweststreetcars.com
