Results 1 to 10 of 23
Thread: 12.7s
    Jun 2009
    Houston,TX
    12.7s
    took the truck to the truck now on drag radials and ran 12.7s on funny gas, but its slugging on the top in on motor, plus check engine light is still on."mass air flow sensor problems. so i know it should be running a lot better.
    Feb 2009
    1/4 mile? nice time if so, whats your mods?
    02 5.3 sierra rcsb,its stock i swear ....
    Jun 2009
    Houston,TX
    Quote Originally Posted by 02gmcbandit View Post
    comp cam, long tubes,tci stall, comp cam valvetrain upgrade, 3.90+posi unit, servo,ported throttle, k&n, nx150, m&h 28" on drag radials. msd inline fuel pump, hp tuner, tuned flaco.
    Quote Originally Posted by 2000gmc View Post
    Yea I think u got some problems there it should run better than that. My rcsb with full exchaust and tb stall with a 100 shot on 22s went 12.9 at 109!
    Quote Originally Posted by jkalwei View Post
    You're telling me you run 14 flat or better on motor with nothing but exhaust and a stall?
    Actually last friday it went a new best on motor of 13.84 at 99. Then i tried to spray the 150 to it and blew the tires off lol.
    check light will prolly go off after you hammer on it a few times
    Jun 2009
    Houston,TX
    Exclamation
    i sure hope so, i wounder if to much fuel will cause the maf code to come on.
    I def. wouldn't be spraying with a MAF problem. Unless you have a wideband to know you're safe.
    Jun 2009
    Houston,TX
    Exclamation maf
    no am not, ill probably take it to get it retune this weekend hopefully that will fix the problem
