Results 1 to 8 of 8
Thread: 4l60e takes a dump
    San Antonio/Laredo
    Angry 4l60e takes a dump
    yesterday was a bad day went to ranch and there just a bit of mud nothing major it was BS someone covers a hole that was full of water with dirt and sand my truck just sunk in i was able to get it out after an 2 hrs of me and my buddy diggin it out and take the water out with a bucket the diff. was just seating on dirt and the tires were in the air we got it out driving it but did slip a bit it ran fine but today i notice when i punched it in 2nd gear it took off like it does and the tran did slip at about 5k rpm and hit the limeter and it shifted fine then i did it again at a 70 mph punch it slips for like a sec. then it get the gear fine but i have noticed that it does it sometimes not all the time i wonder if my tranny did take a crap we did not rock it in the mud or spun it in the mud it never really touch the ground the tires where spinning in mid air just would throw up water i have check the tranny fuild looked kinda watered down the truck was in water the water was up to the bottom of the door im wondering if water got in the tranny it was in water for about 2 hrs or did the tranny did take a crap what do you guess think im gonna change out the fuild tonight after work and see if that takes care of it if not what other thing can it be any help or ideas are appreciated
    thanks
    Sep 2009
    Charleston, SC
    Mines been acting like for the last 30k miles, also slipped at green lights after a highway run. I finally installed a rebuilt (with mods) and problem solved. This started at about 90k for me. What's the milage on your truck?
    03 ecsb LS1Cam (4now), Electric Fans, Exhaust, Ported TB, rebulit 4l60 w/shift improvements&stall 130amp Alt,Magnaflow exhaust
    http://www.cardomain.com/ride/3101653
    San Antonio/Laredo
    I just hit 115k I'm having my brother swap out the fuild I'm at work right now cause I checked the oil and it does look like it has water in it if not I got a spare 4l60e and I'm justsaving up for my 4l80e I got a 6.0 already right now I'm just pissed cause someone covered the puddy of water with dirt and sand I just sunk in it sucks I hope I find the prick that did that ill post up some pics later I was knee deep in water
    San Antonio/Laredo
    Thumbs up
    i think i found the problem already i had check the fuild and it look liked it had water well i got to the bottom off it during my lunch at work i went to work on it i check the fuild again and it was low so i started to check the lines and i found it it has a pinch on the tranny line and i saw it was mosit with oil so i think what would explain the problem im gonna fluse the tranny and fix the line i cleaned the line and put some jb weld for the mean time i dont get out of work till 1 i hope it holds for the mean time i dont want to burn my tranny just yet i hope this fixes it i feel abit better now
    I would do a COMPLETE flush of the tranny, lines, and cooler (if equipped).
    So your line was pinched and there was a hole in it? Not completely sure if JB Weld will hold. I wouldn't put any bets on it. I would definitely look into replacing the lines!
    San Antonio/Laredo
    Exclamation
    update I got out of work added oil took it for a drive drove fine for about 2 miles of stop and go traffic then I got back to work checked the fuild it was low again so i checked the rad. And I found my tranny fuild in the rad. so I got a new rad. from a 2500 burban and it has the cooler and I still got a tru cool 40k cooler so I'm gonna work on it tonight is there anything else u guys can think of before I tear it apart
    Well, the tranny cooler lines go into the radiator. No real need to buy a new one. If you get the 34" radiator, you are gunna need to get the correct hoses for a Suburban and bend the cooler lines to reach it.
    If you add the 40k cooler (which is an excellent idea), make sure to sure the proper clamps and cooler line extensions to meet with the existing cooler lines.
    San Antonio/Laredo
    yeah i got the 34 and I got the lines don't know if they r the same cause it has a 4l80e which I'm saving for my 6.0 swap I got the whole burban and it has the ext. cooler in the front do u know if the lines work ? And thanks man by the way my name is rosendo but everyone call me ross
