Results 1 to 7 of 7
Thread: (an) Fittings
    Question (an) Fittings
    Someone Please Explain The Sizes Etc,,i Want To Order Some Nice Line And Fittings For My Tranny Cooler To Get Rid Of The Regular 3/8 Hose with clamps that I Have,,but There So Many ,6,7,8,9 An,,why Cant It Just Be 3/8 Or Regular Sizes Lol,,so How Do I Figure This Out?
    Put the number over 16 to find the size. -4 is about .25", -6 is about .375" (3/8"), -8 is 1/2", etc.
    damm why is it so complicated lol i hate math,,anyways thanks as long as i know -6 =3/8
    Mar 2007
    Austin,TX
    Quote Originally Posted by STUNNA View Post
    It's because it's also a different type of fitting. A true AN fitting will taper so be careful when installing them. If you are replacing the transmission line fittings be careful not to overtighten them or you risk cracking the housing.
    newburgh, NY
    Quote Originally Posted by randomhero View Post
    A true AN fitting will taper.
    Not all AN fitting are tapered. If it a flared fitting it will have straight threads If its pipe it will be tapered.
    A AN flare fitting is nothing more than a 37/45 degree JIC industrial fitting.
    Step 1. crus at it.
    Step 2. get a hammer.
    Step 3. torch it.
    well i actually removed the tranny lines where they hook up to the radiator and ran an external tarns cooler,,but i did it with regular fuel hose and clamps,,i dont really trust that crap,,so i want to make it look clean and sturdier.
    Rubber type fuel line works fine for a tranny cooler, only I like the spring typle clamps (think thats what there called) over hose clamps. Aesthetically braided stainless and -AN fittings are nicer though.
