Thread: '00 ABS problem
    Jul 2004
    Wondering if anyone has experienced this problem with ABS..
    My 2000 Silverado xcab 4x4's ABS engages whenever I'm slowing to a stop (i.e. 10 -> 0). This happens at every stop, regardless of surface conditions. If I'm more aggressive on the stop, the ABS does not engage. I have 285 MTs on the truck but this problem started well after changing from OEM 265 tires. The only off-roading I've ever done was my muddy semi-gravel driveway a few times (got bad enough for MTs though)..
    Damaged ABS sensor? Dirty sensor? Something more serious?
    Anyone have an idea where I can find instructions on testing an ABS sensor (I assume this can be done w/ a multimeter?) I've yet to get to a bookstore for a Chiltons e.t.c.
    Thanks in advance!
    -Brian
    Jul 2004
    I'm 99.9% confident a misbehaving front wheel sensor is the culprit. And not an ABS pump (whew&#33 I'll post the resolution as my search of this site didn't yield anything. Now I hope both front sensors are identical as it'd save me a bit of upfront diagnostic work.
    Need a wheel sensor and a 4wd switch. What sponsors of this site sell OEM parts?
    Is there a list of sponsors somewhere?? (I looked briefly, didn't find)
    Thanks!
    Apr 2003
    Mansfield, Texas, USA
    Haynes has manuals out for the 99+ trucks now! I'm going to get one shortly.
    Is there an ABS exciter wheel up front? Maybe it's soiled/bent?
    ABS modules here are about $150 used FYI
    Mar 2006
    Quote Originally Posted by brian9990 View Post
    Thanks in advance!
    -Brian
    My truck done the exact same thing one day when we were doing some tuning.....just as you descibed......all we done was calibrate the tire size into the program cause we had forgotten that and it was then fine. The difference in your tires size makes the truck think it is scooting the tires slightly.
    hope this helps you before you spend money you dont need to spend.
    you can do this with software or maybe take it to gm and they can do it
    Jarrod
    Thanks in advance!
    Aug 2005
    St. Anthony, Indiana
    Quote Originally Posted by carfreak07 View Post
    Jarrod
    Thanks in advance!
    this thread is 3 years old!
    Mar 2006
    lmao....why the hell is at the top of my browser as a new post
    I guess I havent taken the time to adjust to this new site huh?
