Thread: possible good use for Tb spacer?
    Southern WI
    So for my machining class at school were working with lathes and drilling and tapping. Well I have a useless Tb spacer on my shelf and have been wondering if it'd be possible to machine down the center bore so it was smooth instead of the spiral, and drill and tap holes into the top where I could screw nitrous and fuel fittings into and make my own plate setup? I found these on the internet and thought I could drill the holes all the way through the spacer and use 2 of these to direct my fuel and nitrous. Just a thought...im open to any comments!
    Nitrous Outlet Product Details - Nitrous Accessories - Nozzles, Jets & Accessories
    Mike
    2000 RCSB
    nitrous plates have "vents" machined into the smoothed area, basically just holes drilled up to the fittings im sure it would work just not sure how well.
    Southern WI
    Thanks G..i know that you, jon and virgil are the top guys who know about spray on here, I guess I'll give it a try, and just start out with smaller shots (50-75) and see how it works.
    Mike
    2000 RCSB
    im still a newb compared to them if you want some pics of my plate lemme know ill take some for you.
    Birmingham, AL
    i use my old TBS to hold down my tool box
    01 Silverado
    Nov 2006
    Mesquite, TX
    yeah you can make your own plate using a TB spacer...there was someone on here about a year or so ago that did it and said it worked well
