Results 1 to 10 of 10
Thread: Truck oil pan, DBW TB, 3" header reducers, and more.
    Spiro, Oklahoma
    DBW Throttle body, 3" header reducers, LS adapter plates.
    Early 80's Blazer bucket seats, recovered and almost like new. $40.00 picked up only.
    88-98 OEM hood. free to whoever will come get it out of my way. Recently stripped and epoxy primered (looks better when its not covered in body filler dust)
    Stock truck injectors from an 05 silverado. I don't know what these are worth so just make me a reasonable offer.
    Jegs nickle plated fittings both are 1/4 NPT X 3/8 barbed. $7.00 shipped for the 90* $5.00 for the straight fitting.
    Energy suspension poly ball joint boots, OBS. $8.00 shipped PENDING
    DBW throttle body from an 05, has around 30k miles on it and worked great but I just switched to a cable setup.Make me an offer.
    Standard LS adapter plates. I changed to a 1" set back. I welded in a bolt that would allow me to turn them upside down on the opposite sides and set the engine forward enough to keep the A/C in the stock location but that led to drive shaft issues so I changed back, the studs don't interfere with normal mounting. I have most of the bolts that came with the kit. $15.00 shipped
    2005 truck oil pan, windage tray, and pickup tube. The pan has some scrapes on the bottom from the truck it was in being so low but it is structuraly good. SOLD
    Jegs 3" header to 3" pipe reducers, missing a flange in the picture but if anyone is interested I will round up another. $20.00 shipped
    Passenger side only Shoenfeld conversion header. I screwed up the drivers side header and had to order a new set. Has a 3 hole collector flange welded on. 40.00 plus shipping.
    All prices are best offer, I take paypal. feel free to request additional pics or info. Shipped prices are lower 48 only.
    pm me . i want those energy suspension boots if they would fit my 2003 SS
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
    Plainfield, IL
    they are obs...shouldn't fit
    dang!
    ff_jeff Guest
    Ill take the header gaskets... PM me your paypal.
    Spiro, Oklahoma
    Bump
    Spiro, Oklahoma
    Apr 2006
    Muldrow, OK
    Hey man,
    I'll take the ball joint boots.
    Also, I need to see your truck sometime! I'm over in Muldrow and have seen you post on here a lot and am surprised I haven't seen you driving around the Fort. Anywho, I'll take them.
    Thanks,
    Cody B.
    -Slow Is Not An Option-
    93 Stepside - Forged 347 - LS6 intake - Stage II LS6 Heads - MTI X1 Cam - Vigilante 2800 Stall - HP Tuners - Schoenfeld Headers - 4.11's w/Powertrax - Caltrac's - 430/400
    02 Trans Am - Forged 408 - Single Plane GMPP - 96lb/hr Injectors - HPT 3 Bar - Twin 67mm Turbonetics - Huge FMIC - Moser 9" - 4L80E - Alky Control Meth - Jesel J2K - Eboost2 - waiting dyno
