Results 1 to 5 of 5
Thread: Do I really need...
    Dec 2004
    San Antonio, TX Area
    Do I really need...
    a higher stall torque converter? Or an aftermarket cam kit? My plans for the truck are daily driver, and may only see 20 or less passes a year at the track. The truck is a 1990 with an LS1/4L60E, 3:42 gears, Eaton LSD, and electric fans.
    But if I do. This is what I am thinking of going with, this cam 224/224 .581/.581 114 LSA, or the Old Man Truck Cam 214/220 .600/.523 115 LSA, with this stall 3000 (Circle-D), Trans-Go kit. I may also go with 4:10 gears. Do I need the 4:10's or will I be able to get away with the 3:42's for now? 15" wheels for now, undecided on the tire size. So what do you think? I figured instead of asking I would just do a little bit of reading and make a choice. Then I could take suggestions for a better choice of cams, torque converter, and gears. Forgot to add, I may also get some underdrive pulleys. Thanks Art...
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Augusta, Ks
    Go big or go home. To reap the benefits of the cam and stall I would go with 4.10s
    2004 Buell XB12s
    Ponca City
    Quote Originally Posted by WARLOCK View Post
    +1
    Slowest in Oklahoma...
    Round Rock, TX
    Build it for yourself not everybody else...Just depends on what you want from the truck....
    San Marcos Texas
    Try it out first and see what it will do! I ran a 13.7 in my '81 with all stock LS1 and no stall through cats 3.73 gears.
