Results 1 to 10 of 12
Thread: gettin a tune, need input
    Aug 2009
    New Orleans
    going to get my truck tuned as soon as i get my cam in.(hopefully this weekend) i wanted to make shure i got everything i need sorted out beforehand. also got a few questions before i go get it done.
    05 ecsb 4.8
    -mods
    volant cai with ram air
    bypass coolant through tb
    flowmaster 40 series
    transgo hd2 shift kit
    vette servo
    30,000gvw tranny cooler
    changed from 3.23 to 3.42 gear (i'm going to 4.10 when i get a true trac)
    comp 218/224 .527/.532 on 112 ls6 springs and comp hardened 7.4's
    so this i what i was thinking so far
    -93 tune
    -eliminate top speed limiter
    -raise shift points
    -change gear/tire size
    -what does eliminating skip shift help?
    -how much TM to remove?
    -maybe lower fan activation temp?
    -would it be worth changing to a lower temp thermostat?
    i know i need a converter but its not in the budget yet. i was thinking the posi first since i already have the 4.10 gears. i been looking at circle d's. what stall should best suit my cam? i still occasionally tow so i don't want to go too high
    any suggestions are appriciated
    If you have a stock tranny, keep 20% TM. Fan wont help unless you have a 160 stat. Converter will need a re tune. Posi, asap.
    Aug 2009
    New Orleans
    yea the tranny is stock so i figured to leave a little to prolong it for a while. and no more wot downshifts. not really looking for an excuse to rebuild it. lol
    what kind of gains you get from the 160 stat? wheres the best place to get it? autozone?
    also what about getting rid of the egr?
    Spring, Texas
    Quote Originally Posted by jpstreetracer95 View Post
    The 160 stat will just allow coolant to flow sooner and in theory keep the temps cooler (if fans are tuned for it). It may allow for a couple of degrees of timing advance for some extra hp. If you need one, let me know. I just bought one that I'm not going to be needing. They're cheap too. I only paid like $12 +shipping for mine.
    Jul 2005
    Azle , Texas
    New finding is 185* thermostat , says makes much better power than 160* and runs a little cooler as well .
    Now what is a tune again?
    Comp Cam 54-412-11 , Int:265, 212, .522 , Exh: 271, 218, .529 , LSA 114 , Longtube , CAI (Vararam) , TransGo HD2 shift kit , tuned by me with EFILive
    Mar 2008
    Burleson, Texas
    Not sure of your year. If it's 04 or newer you can get a MR gasket 160* from Autozone for $13.49. If it's an 03, have them order part number 37960. It's the whole housing, 160* for $30
    '00 Silverado 4.8L (Gone)
    '11 Silverado 4.8L
    Quote Originally Posted by RUFFNECK View Post
    ...First relieve the pressure before doin' that or else you will get a nasty squirt and may get in ur eye.
    egr can be taken out by the tune
    Victoria, Tx
    you having Geoff at EPS tune it baton rouge?
    67 Camaro SS 350 and a 67 Camaro back half car
    99 Z28 Camaro (Old motor - 585rwhp / 602 rwtq)
    97 Nissan Maxima
    00 Chevy Tahoe
    21 Model T Roadster Pickup
    65 FFR Shelby Cobra w/501ci BBF
    57 Willys CJ5 Jeep
    MD250 Mustang Dyno - EFI live
    Aug 2009
    New Orleans
    my dad gave me a number for Futral its in walker,la. i was thinkin bout goin there.
    have'm hook the wb up and dial in a/f ratio.
