Results 1 to 9 of 9
Thread: 500hp 6.0 vortec
    Jul 2009
    500hp 6.0 vortec
    I am puting a 6.0 vortec in my truck. I am planning on using a set of cnc ported l92 heads. Could I get these power numbers with the factory intake and injection sytem?
    Oct 2008
    Houston
    stock truck intake will definitely be getting in the way at high rpms.
    cam and bolt ons with those heads and a good intake should net you 500 on motor.....possibly.
    Birmingham, AL
    stock injectors, no
    01 Silverado
    Jul 2009
    what about with bigger injectors?
    Birmingham, AL
    right size injectors, good heads and high comp. and you could do it
    01 Silverado
    Nov 2006
    Elk Grove, CA
    I would say match port the intake too that way you get full benefit of the heads
    Jul 2009
    alright say 10.5:1 comp with the right cam, bigger injectors and maybe a little porting of the intake then 500hp would be possible
    Nov 2006
    Elk Grove, CA
    Thats a close call. Depends on what cam. I would say at least a 230 duration 560 lift cam. If you could get a smaller combustion chamber to get you closer to 11:1 that would be a for sure 500 horse motor.
