Results 1 to 10 of 16
Thread: if I changed
    Oct 2008
    Houston, TX
    if I changed
    Motors same size just diff year would I still need a retune
    Airaid, alpine double din,
    San Marcos Texas
    More than likely no.
    Depends. A 2003 5.3L and a 2004 5.3L should have a different tune. The 2003 is not Flex Fuel and the 2004 is FF.
    What motors are you working with?
    Oct 2008
    Houston, TX
    From an 01 to a 04
    Are you swapping EVERYTHING over or just motor?
    Oct 2008
    Houston, TX
    Just motor
    hot & windy
    from 01 to 04, that also changes to DBW & has a different harness/computer, from what i remember
    99 Sierra - 5.3 / 5spd
    Oct 2008
    Houston, TX
    2 much 2 hasle with then
    If you are doing just a stock 01 with a stock 04 motor only, you should not need a retune. And this is just for a motor only swap. This is assuming you are retaining the intake, all accessories, TB, fuel system, etc.
    hot & windy
    switching short blocks should be fine... there's a guy on performancetrucks.net selling an LM4
    All Aluminum 5.3 LM4 For Sale - PerformanceTrucks.net Forums
