I would like to help ya out. I have electrical manual for 2001 trucks. I see circuit 48 on the CPP connector, and the PCM, but can find no info about what happens on it.
The only thing i can find is (hot in run) BRAKE 10A goes through stoplamp switch via terminal D/BRN/441 into stoplamp switch, then out terminal C/PL/420,(stoplamp switch cuts the circuit when the pedal is pressed) then into terminal A/PPL/420 of CPP and out B/BRN/WHT 379 into terminal D of the Cruise Control Module.
The brake and the CPP both CUT 12v to the Cruise module.....I have NO IDEA what happens on circuit 48 or the PCM!!!!
1991 Silverado ECLB
LM7-T56
