on a basic motor ,,say 6.0 6.2??if so what all would have to be done,,besides tune/full bolt on/cam??
just want to know if its possible to run 11's n/a.no nitrous ,no f/i
this set up of course on a rcsb.
I'd say a cam with lots of topend, steep gears, big big stall converter, all the other bolt ons and mods and you can do it!
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
say 4.10's and 3400 stall good enough?
what do most n/a set ups run?say a full bolt on cammed 6.0?
That's not enough. 4000+, 4.56+ trans brake, huge cam and compression. It could happen![]()
I would say that its not too far away. Jons EC truck was 4555 lbs, and he ran a 12.2 N/A so if you were a reg cab of the make, you would be around 4000. So theoretically you would be .5 faster. 11.7 with jons low to mid 400's whp setup and a truck that has been stripped down to 3800 lbs. Then add the driver weight.
The biggest factor would be your 60ft.
damm thats badazz low 12's n/a,fastest n/a 6.0 ive seen was a 12.1 rcsb
If I changed to a L92 head with 11.0-1 compression and a good cam I think 11s on motor would be definately doable. Definately going to need atleast a 3600 stall to along with 4.10 gears.
i thought stewart ran 11s NA in an ext cab (txsilverado) am i wrong about that???
i ran a best of 12.17 about a month ago, been running 12.8-12.3's for the last couple of weekends, head cam full bolt ons, in the heat, plans to hit 11's in the heat come next weekend or at lease a 12 flat runthis is with full truck weight, just spare removed ( RCSB)
gonna need at lease a 4k stalli run the l92 heads and truck intake, patiently waiting on the FAST which will be delivered the 30th of this month ( maybe )
na, that was me, stewart it on nitrousi ran a best of 11.8 in my ecsb
stew did run a 11.5 with a 150 shot though, and is knocking on the door of 11's NA
Simple: 408 on steroids!
single digits coming soon!
