Results 1 to 10 of 13
Thread: water in heads???
    Feb 2008
    Arizona
    water in heads???
    hey guys, I am swaping a 5.3L from my "work truck" that had 198,000mi and was about to give up.. I got another 5,3L from a 2003 Suburban 4wd.. the first of my questions, I removed the intake from my new engine to clean it up and one of the head ports had some water on it.. what can cause the water in the head port?? the engine was sitting for a couple of months.. the second question is, i will replace the tranny also, is the torque converter the same as mine? my truck is the same year as the burban.. I will put also a G-80 that came out of the suburban.. I know they are not good, but is just to improve traction off road..
    btw, I got engine, tranny and G80 for $300 from a good friend of mine..
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Mar 2007
    Austin,TX
    Enjoy that G80 when it breaks and locks up and tears your transmission apart(I've seen it happen). Just because it's free doesn't mean you should put it in. I ran the open differential for the longest time and while it's not optimal the G80 in my opinion is a worse option.
    Feb 2008
    Arizona
    thanks for beeing so optimist.. I run my truck with a G80 and beat on it and never had a problem.. I know G80 (grenade 80) is the worst choice in POSI TRACTION, but I bet is WAY better than running an open diff for such a long time..
    Mar 2007
    Austin,TX
    Quote Originally Posted by White Devil View Post
    That's very debatable, but I suppose do what you will.
    Water in the intake port could have come from several things...leaving it sitting for a while and having it rain on it, the head cracked, etc. Are they the 706 heads? Take the casting number and see if it was made by Castech. If so, I would get rid of them since those heads had major issues with cracks in them.
    The converter will be the same and will bolt right up.
    Did you find this out the same way I did? Anyone heard from Steve lately after the move?
    Feb 2008
    Arizona
    heads are 862's guys.. it was sitting on the rain for a couple of months but had the intake on so I don't know how could the water get in there.. is it possible? thanks!!
    The 862s should be fine. If they were sitting for a couple months, the water was from Mother Nature. Just make sure to use 87 cans of Brake Clean to clean them up!
    Round Rock, TX
    Wow...87 cans @ $4.00 a can.....$348.00
    Plainfield, IL
    G80's aren't as bad as most people claim...I love mine. Got it because the one in our tahoe has 150k on it.
