Results 1 to 10 of 11
Thread: Question About Lowering
    Cedar Park, TX
    Question Question About Lowering
    I have a Z71, and I already lowered my torsion bars all the way. I now only need to drop the rear. I am planning on changing out the u-bolts, but the goober at Autozone told me that doing that will mess up the suspension in the long run. Is this true???
    R.I.P Blue '02
    '08 - 5.3
    Vette Servo, Flowmaster 40
    you answered your own question with the line ''Goober at autozone''
    Jun 2009
    Glennville
    how far are you planning to go in the rear???
    5/9 mchgys\belltech\boss 330\streetscene\reflexxion\flowmasters\servos\tune
    Cammed,Stalled,lts,ory,elec cutout, 4.56,transgo,servos,flowstoppers,
    soon to come a little shot of nitrous
    Cedar Park, TX
    i want the rear to be level wit the front and on the front i lowered my torsion bars ALL the way. I dont know how low that is tho. i didnt measure
    R.I.P Blue '02
    '08 - 5.3
    Southern WI
    Your fine, just do it. I and many others out there have pretty low 4x4's and everything is ok
    Mike
    2000 RCSB
    Plainfield, IL
    I work at autozone...yes most are goobers
    But JUST changing u-bolts won't do squat. Are you just flipping the leafs below axle? If so, you need factory length bolts. Longer length bolts if you are adding a drop block as well... BUT with just lowering torsion bars, that's prolly gonna have a cali lean.
    Lowering/cranking torsion keys will cause the tires to run on an edge instead of perfectly flat...which can cause excessive suspension/tires wear.
    I'm sure the autozoner (the dumb term the company uses for its employees) didn't know any of this...but he was not 100% wrong.
    Round Rock, TX
    I have yet to meet someone that works at autozone around here that even has a clue, much less knows anything about a vehicle. Removing the blocks that are between the leafs and spring perches will do absolutely nothing to anything except lower it that amount. Just go get a alignment done and your front suspension will be fine. I would have put dropped spindles on it myself but to each thier own. I've never been in a torsion style suspension vehicle that had the keys cranked that actually rode halfway descent.
    Call the guy at the parts store what you want but anyone taking all the tension off the torsion bars is a goober.
    Cedar Park, TX
    why do you say that?
    oh, and here's a pic of the front end now. sorry bout the quality. took it from my phone.
    and i've ordered the 2WD U-Bolts from GMPartsDirect. Next ill be ordering shackles
    R.I.P Blue '02
    '08 - 5.3
    ff_jeff Guest
    Quote Originally Posted by sleeper1500 View Post
    I call them Autozobies... with out a part number... they have no braynz.
    Quote Originally Posted by jetersaurous View Post
    Looks good. But your going to rub so be prepared. If you haven't already, when you hit a big dip in the road you will hear a nasty scratching sound. I dunno how the plastic flares will hold up to tire rub, but I would think that they would get torn off. Jon had to roll my front fenders for a 2'' drop in the front of mine cause of rubbing/crazy ex girlfriending my front tires. the wide tires do that.
