Results 1 to 10 of 14
Thread: Opinions on this exaust
    Sep 2004
    Will this set up have enough backpressure I dont want to lose to much bottom end torqe. I have ASM Headers allready installed Im getting dual 2 1/2 into a magnaflow muffler dual 2 1/2 out the back with 18"x4" tips. I am running stock cats this is going on a 03 silverado 5.3.
    http://i15.photobucket.com/albums/a3...lla/breeze.jpg 03 Silverado LS, 6.0 RcLb
    Go: Radix 2.9, 100mm Idlers, GT2-3 Cam & Springs, Long tubes, 2.5'' duals, Cut outs, E Fans,
    Built 4l65e, 2600 Conv, 3.90 Gears, Eaton Lsd, Caltracs, Tuned by F-Body Central
    Show: Eagle boss 309, Toyo's 285/50s, SS Bumper cover & Spoiler, Roll pan, 2'' rear drop.
    Track times 12.304 @ 110.30 with a 1.747 60'
    Mar 2004
    Springfield
    Don't know much about back-pressure..........but geez
    .....think those tips will be big enough?
    FOR ALL YOUR WHEEL, TIRE, AND ACCESSORY NEEDS
    CONTACT: EPLEY'S TOUCH OF CLASSIC 1-270-843-6892
    OR TO GET ME PERSONALLY CALL: 1-615-943-6514
    2000 Chevy Silverado 4.8L RCSB: smoked UPD, Flowmaster exhaust, De-screened MAF, Nelson 93 hot tune. Upcoming installs: trans-go shift kit, Eaton posi, billet servo, ported and polished throttle body...Near future: 6.0/4L80E install with 150 wet shot
    Jun 2003
    which muffler from magnaflow. is it one of the hd muffs. if so you will be fine. 4" tips
    formerly 02denali 12.79@107
    Aug 2003
    Larger tips than the rest of your pipe is a good idea because it creates some resonace and a nicer sound, but 4" is a bit overkill, 3" might be a little better idea.
    1 ton, 4600 pounds, 14.3@94mph any questions?
    I'd go with some 2.25" piping.
    I drove my truck around for a bit with open exhaust, on holy shit, I could hardly burn out in first, normall I can burn out at will in first and continue in second, not without exhaust.
    just a thought,
    allen
    Apr 2003
    Mansfield, Texas, USA
    Um, what's your question now? Sounds like your setup is already done...
    Sep 2004
    Originally posted by Hit Man X+Sep 20 2004, 10:03 PM--><div class='quotetop'>QUOTE(Hit Man X &#064; Sep 20 2004, 10:03 PM)</div>
    <!--QuoteBegin-03silverado5.3
    Um, what&#39;s your question now? Sounds like your setup is already done... [/b]
    The headers are on not the exaust. So it sounds like everyone thinks the tips are to big which would you use. The muffler is a 5X11X22" body 2 1/2 in & out PART#14568. I want my truck to run mid 13s along with the mods I have and Volant cold air, Electric fans, TT2600, 3.90 gears, And Im thinking the same comp cam 02 Denali has. I am hopeing that will get me there. Oh yea some Drag radials and TB spacer. HaHa. I appreciate youre advice.
    Go: Radix 2.9, 100mm Idlers, GT2-3 Cam & Springs, Long tubes, 2.5&#39;&#39; duals, Cut outs, E Fans,
    Show: Eagle boss 309, Toyo&#39;s 285/50s, SS Bumper cover & Spoiler, Roll pan, 2&#39;&#39; rear drop.
    Track times 12.304 @ 110.30 with a 1.747 60&#39;
    Sep 2004
    Man my wife just got home and I had her lay under the Truck holding the Exaust Tips up there they look Bad Ass. Do you think I should really go with 3" tips it seams they would look small.
    Apr 2003
    Yeah, I don&#39;t like tips myself. I hide the tailpipes behind the bumper a la old Cadillacs/TownCars. Plus it limits resonation too. Tips act like a megaphone only.
    I think it&#39;s going to take a bit more than the 5.3 to get you into the 13s all motor. I like 02&#39;s cam but it lacks on the lift and could use a more aggressive lobe IMO. Basically I think there is better stuff out there on the custom end from Comp. Allen is a Comp dealer soooo... find out which lobes you prefer and have a cam ground from there.
    An LS1 or 6.0 swap would probably get you there with more ease.
    Oh yes, I have the similar muffler in my attic to install... DI/DO Magnaflow w/ built in X-pipe.
    San Marcos Texas
    Hahaha I love it when the wives get involved&#33;
