Thread: More PSI?
    So Cal
    More PSI?
    Should i attempt to use more PSI out of first Gear?
    i think im running 86psi to first gear...and i do have a shot pinned after market output shaft in my 4L65E so the trannys pretty built but im running a Billet Servo and i used to br running 91psi and i would be able to chearp the tires and now i cant...id like to attemot to get up there with out blowing another output shaft
    thanks guys
    2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
    Oct 2008
    Houston
    Chirping tires on 4,000+lbs vehicle = broken output shafts.
    Thats a LOT of mass your shock loading into the shaft.
    Keep the stock tranny pressures!!!! If you want more bump in the 1-2 shift, get servos and stiffer springs for the 2nd accumulator.
