Results 1 to 10 of 12
Thread: 4.8 cam idea
    florida
    4.8 cam idea
    hey my tuner jeremy formato wants to install 225/229 111 +3 .596/.602 cam
    what do u guys think about this cam setup with a 3000 stall 373 and lt headers decent low end power ? need some thoughts thanks
    Get some 4.10's and a 3600.
    EDIT - on a 4.8 get 4.56's and a 4000.
    Oct 2008
    Houston
    It will rob low end for sure. .... how much and whether its too much would be debatable.
    florida
    which i already have a 3000 circle d stall with 373s in the rear which price wise he told around 1500 for the complete install and cam and all. i was thinking more of a 224/224 112lsa how would that cam do and looking for a good lope at idle
    If you want a raunchy idle and would still like to maintain most of your low-end power, and 3000/373 setup, take a look at GM's LS1 Hot Cam (218/227 .525/.525 112).
    It has a fairly early intake valve closing event, so you'll get some decent low-end power with your 4.8.
    Here's an idle clip:
    YouTube - 06 Silverado 5.3 - LS1 Hot Cam
    Pittsburgh, PA
    this topic is over and over again. ppl dont realize a 4.8 is a tinyass motor. the gears and stall you run typically for a larger motor dont work so well with the 293. the 4.8 is modernday 302 if you think of it. short stroke so it can rev. you can get away with a decent cam in the 4.8 but you need the supporting mods. you need to spin the motor 7k-7500. doing so you need gears to help you thru the rpm range and large stalls.
    a 3k stall is for a stock motor honestly. 373s unless your running 26" tires arent enough.
    or you could settle for a small cam in the 4.8. even then your stall and gears are to small
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    florida
    so i ran a 15 flat with my mods now how much of a difference would 456 gears make i dont mind it reving higher on the higher i dont go over 70 which my tires are 30.5 height im just trying to get the most out of my 4.8 thanks for ur advice
    Pittsburgh, PA
    depends on what hte ttruck is trapping now with rpms. you could expect 3/10s but that is a general estimate
    412 Motorsports
    florida
    quik its trapping out 89 to 91 which its
    60 2.143
    330 6.220
    1/8 9.654
    mph 72.04
    1000 12.567
    1/4 15.051
    mph 89.63
    if that helps
    Pittsburgh, PA
    Quote Originally Posted by silvyrado4.8 View Post
    60 2.143
    330 6.220
    1/8 9.654
    mph 72.04
    1000 12.567
    1/4 15.051
    mph 89.63
    if that helps
    rpm wise going thru traps. installation of gears help or hurt a motor. ideally you want to be at peak power crossing traps. so you gear and tire for those rpms
    412 Motorsports
