Results 1 to 10 of 12
Thread: Preloading (oiling) lifters
    S.A. Texas
    Ok everything is here and time to get this over with. Only question i have is do i need to preload the lifters. Where you push down on them with a pushrod and get all the air out. I know i need to let them soak, but in what oil my regular i guess and how long also. This is a new one to me.
    El Paso
    Soak them in the oil you are going to use in your motor. Stand up the lifters in a bucket or what ever . Submerge the lifters in oil. Make shure the lifters are standing up when you do this. Now get a pushrod and push down the plunger. you will see air bubbles come out of the oil hole in the lifter.Repeat this untill there are no more bubbles. Your lifters are now preloaded. (The oil level in the container you are useing need to be higher than the lifter when the lifter is standing up.)
    S.A. Texas
    thats what i thought but just checking, any others thoughts
    Southern WI
    That's the exact way I've been told to do it also mark...what kinda lifters did you get?
    Mike
    2000 RCSB
    S.A. Texas
    just the ls7 replacement ones only 150 so hope that is whats been ticking
    Sep 2006
    THE 405
    Do not soak them. Just dip them before you put them in
    2007 RCSB|DTR81 built LSx 3xx|PRC|NX|BOGART|MSD|QUICKFUEL 950 E85|4L80|FTI Converters|Smith RaceCraft|Racepak
    midweststreetcars.com
    Soaking is fine. The real question is if you have stock rockers or ones that require valve adjustment. If they are stock OR do not require adjustment, soak them (doesn't even matter sitting on the side or upright) then throw them in.
    S.A. Texas
    Gotcha thanks buddy soaking in some Royal Purple right now
    Sep 2006
    THE 405
    Heard of them exploding after being "soaked" I'd just dip them before install...
    Man you gotta watch out for exploding lifters.
