Results 1 to 10 of 21
Thread: LS6 cam for a 2000 5.3L
    West Covina, CA
    so... I plan on droping in the LS6 cam and using the STS turbo setup on my 2000 5.3L. I dont know what exact ls6 cam I need or what else I will need to get to do this correctly. HELP please. I know you guys are probably pretty familliar with this. so thanks in advance.
    I will be placing this on a desert prerunner chevy, so any tips on a dirty enviroment would be great too!
    thank you so much in advance!
    -John
    West Covina, CA
    did i mention thank you? I appreciate the help so much! so thanks again
    Nov 2006
    Mesquite, TX
    just get you a nice valve spring like a set of patriot golds and a set of hardened 7.4 pushrods and slap it in there
    West Covina, CA
    ok.. but are there different types of ls6 cams? any patcular year? sorry if I sound dumb... but I am!!! I dont mind spending the money. I just want it done the best i can with the best right parts. reliability is of the utmost importance.
    are those pushrods the same size as stock?
    thanks man.. im really excited about this since i live right next to Irwindale speedway and the run a 1/8 mile "test n tune" race every Thursday... i wanna put this thing up against some vettes and other wanna be hot rods and at least suprise em! maybe even beat a few!!!
    Nov 2006
    Mesquite, TX
    02 up LS6 cam has the bigger lift and duration....
    here's a good place to find the cam Scoggin Dickey Parts Center: GM Performance Parts, GM Crate Engines, GM Goodwrench Crate Motors and Performance Crate Engines
    and yes the comp 7.4 pushrods are the stock length replacement ones
    Quote Originally Posted by mean05 View Post
    Hey I just got my LS6 cam from there...weird.
    Also if you're looking for springs and pushrods www.texas-speed.com has a PRC dual spring and chromoly pushrod set for a good price. That's what I am going to end up going with. The springs are good to .660 lift so more than enough for the LS6 cam, and that way if you did decide to get a custom grind with more duration and lift you would be covered.
    What psi are you wanting to run with this thing? Also how much power are you looking for?
    West Covina, CA
    Talking
    Im thinking around 7-9 psi...haha... so lets say 8psi !!! I would like to see 420+ HP at the wheels. rom what ive read it looks like i might get close to 500 rwhp! but 420+ is pretty good IMO. I'm not trying to get to crazy as it is important I can run the motor 200 miles in the desert and still get it home!
    I really appreciate the info here guys. this is sooo exactly what I was hoping for!
    -John
    Quote Originally Posted by johnh133 View Post
    -John
    I'm a huge fan of the rear mount turbos man but it's really not the most logical thing for you being a desert runner. You could get a lot of power and more reliability for the desert out of a front mount. I would say go with a 70mm that way when you out grow 420 rwhp you just have to turn up the boost.
    West Covina, CA
    thanks.... thats exactly what i am looking for! and that should bump up my HP pretty good right? i have a bone stock 2000 5.3L
    Spring, Texas
    The LS6 cam is a good boost friendly cam, especially if you are on a budget. You can pick them up regularly for around $125. If you want something more suited for your exact application, you can get a custom grind. They are around $500 though. IMO, the LS6 has been proven to produce good numbers with boost.
    As far as pushrods, the 7.4's will work but I believe that you should use 7.425's. The base circle on the LS6 cam is slightly smaller but since our trucks have hydraulic lifters, it is supposed to make up the difference. I've read people have run both lengths and been fine.
