Results 1 to 10 of 13
Thread: Lookinng for a new hood. ???
    Oct 2006
    Wichita Falls Tx.
    Looking for higher then normal cowl hood or comp. for my 00 RCSB. Hoping to gain at least 2 more inches for intake clearances. Looked on line but not sure, without seeing it on a truck its hard to tell.
    Got any suggestions. Needs to be a TRUE bolt on.
    Simply the best turbo kit for late model GM trucks.
    Custom fabrication to fit your budget and needs.
    Dealers for Precision, Comp. & Magnum turbos.
    Online Store
    [/CENTER]
    Jul 2007
    Colleyville, Tx
    good luck... I searching for one last month and couldnt find a bigger one then a 2 1/2.. Only other way i can think of is a custom molded in one a body shop can do. then again you have a 00 style so you might have better luck then i had.
    Pittsburgh, PA
    i have a GM goodmark hood. i have one of the first ones where they height wasnt that tall. the later models are slightly higher
    if you find a Reflexxion cowl hood its taller then hte good mark hoods
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Oct 2006
    Wichita Falls Tx.
    You got to love it when you are shown one thing but not on your applicaiton.
    was first shown this one but its a late model.
    Then for my year model I see these options. Looks like the 2nd one has more room in front. Not sure yet, I was hoping for something in the 3-4" range but still a steel hood.
    Online Store
    [/CENTER]
    newburgh, NY
    Did you ever find one?
    I want a 3-4 inch cowl.
    Step 1. crus at it.
    Step 2. get a hammer.
    Step 3. torch it.
    Oct 2006
    Wichita Falls Tx.
    NOt yet, I want a 4" cowl but does notlook like anyone builds them that tall..
    Online Store
    [/CENTER]
    Birmingham, AL
    Why not make your own?? If you can build what you do, seems like putting a cowl in a hood wouldn't be too hard.
    01 Silverado
    Oct 2006
    Wichita Falls Tx.
    Quote Originally Posted by mitch cobb racing View Post
    If it was billet maybe.
    Might have to try, still a little way from that point. In the past every time I have tried body work has not turned out that great. But that was a long time ago.
    Online Store
    [/CENTER]
    Plainfield, IL
    4.75" .... fiberglass is fun (and a PITA)
    Cut a hole in the hood and let it all hang out.
