Results 1 to 10 of 10
Thread: Header Gasket And Locking Stud Choices?
    Mar 2008
    hampton bays NEW YORK
    I Will Be Putting On A Set Of Gibson Shorties And I Know There Are Alot Of Gasket Companies As Well As Gasket Material Choices Also There Are Locking Studs Like Percy's Or The One Where The Tear Drop Tabs Locks Against The Header Tubes. Any Help Would Be Appreciated I Dont Want Leaks Or Have To Re-torque Them.
    Mar 2006
    Mesquite
    Use your stock manifold gaskets.
    I've always used stock manifold bolts with no issues.
    Pittsburgh, PA
    stock MLS gaskets are the best... you can use stock bolts or use the studs fro ma v6 as in 3.1
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    George.....header gaskets? What did I miss?
    Mar 2006
    Mesquite
    Title says "header" - he prob confused it with "head"...
    Thanks Moze. That's what a figgered but wanted to know if there is an MLS header gasket 'cause that would fix a lot of dudes' problems with cheaper headers.
    Pittsburgh, PA
    i have the stock MLS header gaskets. if you get the later ones they have larger ports for the big boy headers and heads.
    412 Motorsports
    Dec 2008
    South Carolina
    the stage 8 header bolt lock kit from summit racing worked good for me. They use retainers that fits over the bolt head and locks the bolt against the header tube
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    Mar 2006
    Mesquite
    Aren't the stock manifold gaskets copper? MLS is steel...
    No the exhaust gaskets are steel but have no giz.
