Results 1 to 10 of 10
Thread: Need help with transmission problem.
    I was driving the truck today and it went to shift into 4th and revved to about 4500 and then shifted hard. I slowed down to see if it would do the same thing, it did the same thing except it would not accelerate after it shifted. It was like it was in neutral. I pulled over and it would not move in any forward gear. I put it in reverse, and it moved about 10 feet and jumped out of gear and wouldn't move at all. After I had it towed home, I got underneath it to look at it. I grabbed the driveshaft and was able to turn it about a half of an inch. After I moved it, it seemed to have locked in place (it would not rotate in either direction). Started the truck and had reverse again. So I dropped the pan, no big pieces of metal, just alot of metal glitter. Any ideas? It is a 2001 4.8 RCSB. The fluid was clean and full before this. There were no problems before this, drove and shifted fine. Thanks Chris.
    Augusta, Ks
    Sounds like you need a trans bud.
    2004 Buell XB12s
    Ottawa, ON
    Sounds like one I fixed not that long ago, forward sprag clutch let go and a bunch of pieces fell into the input planetary gearset and split the carrier in 3 pieces, what a mess! If that's the case you need a new tranny. (cheapest route)
    Oct 2008
    Killeen, TX
    Sounds like you have revved the engine in Neutral and shifted it into gear a few times to burnout...the result is a clean input shaft instead of geared shaft.
    2007 Chevy Silverado Classic 4.3L V6
    Magnaflow Muffler, CFM Technologies CNC Machined High Flow Vortec Throttle Blades, STS Rear Turbo, Intercooler, Accell Distributor and Coil, 8mm wire, Autolite Platinum plugs, Runs out of fuel at 4000RPM. Marine intake with larger injectors soon. Hoping to squeeze 10psi.
    Quote Originally Posted by Wildman View Post
    No, I have honestly never done that. But, I am in the process of pulling it out now. I have got everthing unbolted. The only thing that I have left is the torque converter bolts. How do you get to them? Thanks.
    I vote snapped shaft too among other things.
    Aug 2005
    St. Anthony, Indiana
    pull the starter and you get to them there.
    OK Thanks
    if they have round heads instead of hex heads be careful not to strip the allen portion of the bolt
    [Today 11:15 AM] MidnightRider: justin= generalvehicles.com moderator
    Yep 8mm off the top.
