Results 1 to 9 of 9
Thread: Well what do you think?
    Waco,TX
    Arrington K1 426 short block
    Bore is 4.080/stroke 4.080
    Compression is 10.3-1 with a 72.4cc chamber head
    4340 Steel Crankshaft with Clevite Main and Rod Bearings
    Arrington molly filled piston rings
    K-1 H Beam Bushed Connecting Rods w/ARP2000 Rod Bolts
    Wrist Pins and Locks
    ARP Main Studs
    Pro-Gram Billet Main Caps
    Stock Shot Peened Main Bearing Caps
    Dura Bond Cam Bearings
    High RPM Oil System
    Remove all flashing, chamfer all 90deg corners
    Radius bottom of all cylinder bores
    .0625" chamfer radius throughout oil system
    MicroPolish bearing surfaces(including wrist pins)
    Micrometer measurements of all bearing surfaces; hand match individual bearings to journals maintaining .0001" tolerance.
    Sonic checked cylinder bores
    Hand Chase Threads
    Hand Clearance for Stroker Assembly
    This engine is a NASCAR grade machined, assembled and finished by Arrington Engines.
    2007 SRT8 Jeep Grand Cherokee
    Apr 2005
    This going in the minivan?
    Gone, but not forgotten!
    May 2006
    Waco TX
    Are you thinking about doing the 426 wade?
    I approve!
    Oct 2007
    Bandera, TX
    sounds slow...lol.. j/k should be a beast
    single digit street truck
    for build info
    Waco,TX
    The seller has it up for a really really good price I might buy it now and hold onto it
    Ottawa, ON
    Sounds like a beast! Sounds expensive too.
    Santa Paula, CA
    Quote Originally Posted by Srt8Jeep View Post
    ARP Main Studs
    High RPM Oil System
    Hand Chase Threads
    ^^^ = fast right
    Quote Originally Posted by sleeper1500 View Post
    Done took 'er down to the Pep Boys an pimped it out.
    03 silverado 5.3L
    H.I.D's, 40 series Flow dumped , CAI, 2in Shackles
    03 Tahoe- C.A.I, magnaflow, h.i.d's...more to come
    Jun 2007
    For a jeep?
