Results 1 to 10 of 20
Thread: 5.3 Rebuild
    5.3 Rebuild
    I have a 2000 5.3 that was pulled from a truck. It had some overheating issues. When i took the heads off all the coolant ports were clogged up with a rust looking crust. The number three piston had a small hole in it but it wasnt all the way through.
    I would like to build a motor the would be in the 350-400 hp range and would be super reliable. I would like to get your opinions on what you would do and maybe even why. I dont know much but I am willing to learn and i would appreciate the advice.
    wcodyp
    Augusta, Ks
    Do a P&P and valve job on the stock heads. toss in a tr220, some Long Tubes, and a nelson tune to start
    2004 Buell XB12s
    Another question is since it overheated would i have to bore the block out or can i do with just get it honed out. I can see shiny spots but i was told that was normal with a high mileage engine. Also i would have to replace that one piston for sure shouldnt i replace all of them at the same time? I know its olf the wall but could i use 4.8 pistons since they are flat topped to up the compression?
    Augusta, Ks
    If you plan on doing F/I or nitrous I would put 4.8 flat tops in it. They are stronger and better for thing such as that. As for your other questions. I have no idea.
    2004 Buell XB12s
    I want to run N/A but i also want to leave myself open where if i do want to upgrade i can without redoing everything, but that would be way down the road. i just want some thing soild to start with. And thanks for the help so far.
    Augusta, Ks
    No problem. If your looking for information, this is the site to be on.
    2004 Buell XB12s
    Houston
    bore and stroke to a 5.7 all u need is ls1 rotating assy and machine work
    Alright and thanks for all the help from both of you.
    Sep 2006
    THE 405
    You can't use 4.8 pistons on 5.3/5.7 rods
    2007 RCSB|DTR81 built LSx 3xx|PRC|NX|BOGART|MSD|QUICKFUEL 950 E85|4L80|FTI Converters|Smith RaceCraft|Racepak
    midweststreetcars.com
    Oct 2007
    Bandera, TX
    nope, diff pistons, rod length, and stroke.
    single digit street truck
    for build info
