Thread: stall..
    Feb 2008
    Arizona
    stall..
    like some of you read my last thread, the
    oil pressure in my truck is a bit low, so I got to test drive my truck after the heads, cam, etc install.. I did it but very slow around the block.. didn't get to step on it.. my ? here is.. this is the first time I drive a truck with an aftermarket stall, I know I was going to feel a lag in my take off's.. when am I going to feel the stall improvement? do I need to power brake to be able to feel that improvement? sorry for my dumb ??, but I am new in this..
    thanks!!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Round Rock, TX
    Quote Originally Posted by Felix Arrizon View Post
    thanks!!
    you will feel it as soon as you put it to the floor, your tires will like it too.
    Maybe a little sluggish light throttle but should feel a lot stronger when mat it from low speeds.
