Results 1 to 10 of 27
Thread: Tru Cool with bypass or not?
    Lawrence, Ks
    I live in kansas and temps in the winter can get cold, I will drive the truck when it's under 30 degrees for sure. Should I get a 40k tru cool with the bypass or just stick with one that does not have the bypass? I will eventually have a cam, higher stall, headers ect...... Is a 40k cooler over doing it?
    Edit: 04 RCSB
    Oct 2007
    Bandera, TX
    nope, the rad. cooler will also serve as a warmer in the winter. You should be fine. no bypass needed IMO.
    single digit street truck
    for build info
    Augusta, Ks
    Where in kansas are you?
    2004 Buell XB12s
    Lawrence, Ks
    Lawrence
    Oct 2008
    Houston
    When it gets to -10 you can always just put a cover over it.
    Lawrence, Ks
    So a 40k without bypass won't be too big/cool and I should be good with that one? Will the tru cool mount in front of the radiator on an 04?
