Results 1 to 5 of 5
Thread: need help with 6.0!!!
    im about to buy a used 01 6.0 miles xxx,xxx....
    what should i do to make sure it wont break down or leak shoud i change all the gaskets?
    Apr 2005
    A little more information on the miles would be helpful.
    That said, these gaskets are sealed very well. I wouldn't worry about them unless you are breaking the seal on them. Then with that many miles, I would replace.
    Gone, but not forgotten!
    Feb 2008
    St Louis, MO
    I think you can get all the gaskets for an entire engine rebuild for around $350. I would probably do that route if you're going to build the motor at all. If you're just taking it out of one truck and putting it in a different one without putting a cam in it or anything else internally, I'd probably just leave it alone.
    <>< Nick <><
    More Pics of the Z28's:
    http://www.omnipotent-goku.com/iroc/gallery/album140
    Cromwell, CT
    maybe put a timing chain in it. I've seen an ls1 that was sloppy at 50k
    Feb 2008
    St Louis, MO
    Yea the chain on my LQ4 was pretty loose when I pulled it off and it only had 107K on it.
    <>< Nick <><
