Results 1 to 10 of 17
Thread: Front noise
    El centro, Ca.
    Front noise
    I had asked before about a scratching noise coming from the front. I did an inspection this past weekend and couldnt find anything hitting the rotors. Can it be a bad CV axle? I had the torsion cranked up pretty good, and it looks like most of the grease leaked out.
    2005 Silverado 4x4, 6" RCD lift, M/T Classic locks on BFG KM2's, 4:56 gears, Air-raid CAI, TB spacer, Nelson tuned, Corvette servos, 160 thermostat, Ebay long tube headers, Flowmaster Delta 40, Cognito Motorsports steering upgrades. 2000 Ford Lightning, 2.3 KB, bolt ons, 7.67 on the 1/8th.
    Hanford, CA
    Could be. I would also check your hub.
    Have you had any ABS or traction lights come on?
    '01 Silverado ECSB - 5.3L, K&N, BONE STOCK(For now) 7.5'' Fabtech Lift on 20'' KMC XD's wrapped in 33'' Micky's
    '72 C-10 SBC - 5.3L, 4L60E, MSD, K&N - still a work in progress.
    El centro, Ca.
    New CV axles, new hub and still making the noise. Im very fustrated, cant seem to find the problem.
    Augusta, Ks
    Turn up the radio. jk Hope you get it figured out. I know that noises can drive you crazy. I just delt with one last week. My truck made a loud thud sound everytime that I hit a bump, like a shock was bottoming out. Ended up being my back seat wasnt hooked and my sub was banging it into the back off the truck. Weird.
    2004 Buell XB12s
    El centro, Ca.
    My truck is making a scratching type noise, front driver side. Ive changed the rotors, brake pads, CV axles and wheel hub. Thought maybe the pads where rattling so I put that brake grease/glue on them, still making the noise. Maybe I bent the caliper bracket when I hit some water on the road. Maybe the caliper isnt applying constant pressure to the pads. Dont know but its killing me. I just came back from a trip down Baja, so I know its something simple.
    Augusta, Ks
    Do you have a way to get all 4 wheels off the ground? If so put it in 4 wheel drive with the front wheels off and pin point it.
    2004 Buell XB12s
    El centro, Ca.
    Did that at work, no noise.
    Augusta, Ks
    Sounds like a wheel bearing to me but you said you already replaced that.
    2004 Buell XB12s
    El centro, Ca.
    Replaced it on Friday, before I left down to Baja.
    Augusta, Ks
    Are you for sure of the side thats making the noise?
    2004 Buell XB12s
