Results 1 to 10 of 23
Thread: duramax?
    duramax?
    Anybody thought of a diesel conversion?
    YES. I have. Ive always wanted to put a diesel into my truck, but I dont know if its ever been done in my body style, let alone could be done. frames might be completely different. Maybe when they come out with the 1/2ton diesels they will work
    Oct 2007
    Bandera, TX
    its been done in the obs,
    single digit street truck
    for build info
    Houston
    it can be done! you might need some motor mounts made but frame rails are similar ive put a 8.1 in a 1/2 and only one mount had to be modified and idk how well the Alison fits in a 1/2 ton trany tunnel the Alison isnt huge but its not small ethier
    Oct 2006
    Wichita Falls Tx.
    I have a Dmax engine and harness for sale. It has been done. I would use the 80E over the alison. That thing is just HUGE and just to build one out you are looking over 3500.00.. No trans brake options that I know of, and you have to modify the tranny tunnel area heavily to make it fit.
    Simply the best turbo kit for late model GM trucks.
    Custom fabrication to fit your budget and needs.
    Dealers for Precision, Comp. & Magnum turbos.
    Online Store
    [/CENTER]
    Houston
    Quote Originally Posted by Turbo6.0L View Post
    id love to have one but just blew all my saved up $$ on mine but it was well worth it
    Oct 2006
    Wichita Falls Tx.
    Luke so if you ever need a spare I have one.
    Online Store
    [/CENTER]
    wow thats good to know the frames are the same?
    Houston
    i dont think they are exatly i probably should measure both mine to see i know that the trany cross member is different and a 80e probably would be better for strip and i was thinking ats made a race type 4 speed but just checked there site and no 4 speed
    but i do love alisons they are so easy to build and they are just a simple trans they are very cool i think just not in a 1/2ton
    Wichita Falls, Texas
    I know its been done in a 69 or 70 model c10 2wd sc/sb. It even had an edge juice programmer on it.
