Results 1 to 10 of 10
Thread: stall? truck feels slower?
    Jackson, TN
    is it me or dose a stall just make your truck seem slower? It takes off alot quicker no doubt but seems like the pull stops but on the other hand it seems like the speedo is moving quiet fast.. I just dont get it lol
    Also after the stall was put in, My truck idles funny, serges while in gear.
    '05 GMC RCSB 4/6|5.3|LTH-ORY|CAI|4L60E|Transgo HD|Vette Servos|DynoTuned|Tru-Trac|4.11s|3500 PTC|
    4 link, fuel cell and 200 plate kit in the making
    Shreveport, La
    dont lose hope man. I just got my stall in and its doing crazy stuff too. Im told to get a retune for the stall before I get too mad about it... Good luck man
    Chris
    2005 5.3l CCSB- 220r/114, full bolt-ons, 4.56/trutrac
    2004 VHO LQ9- Heads/Cam/Full bolt-ons SOLD and missed
    More Pics-
    http://s417.photobucket.com/albums/p...6/ls1%20truck/
    Jackson, TN
    Quote Originally Posted by wayfastw86 View Post
    Chris
    Well atleast I'm not the only one (unforntally) thats having small problems. Dose your truck feel like it should be pulling harder? I'm going to the strip tomarrow so the time should tell the tale! even know my tune is all jacked up with now
    Shreveport, La
    no I wouldnt say its pulling slower, it pulls fine. its just been doing weird stuff like... surges, at wot it feels like it almost slips just before the next gear and now it wont lock up when im at highway cruising speeds. If im in top gear around 70mph it stalling way up like 3500 almost like its in 3rd gear. and when i let off it goes back down to 2000 and as soon as i hit the throttle again it revs back up to 3500. but when I manually shift it to 3rd the rpms rise to about 3700 or so and I can feel it shift into 3rd and then when i let off i can feel the motor slowing the truck down. so I know its shifting to 4th but its almost like it dosent lock up. hopefully it in the tune cause i dont wanna drop the tranny again... well see
    More Pics-
    Crossett,Ar
    Um... When you say feels slower are you actually stalling it up and giving it all its got?
    Or do you mean just cruising? It is going to be slower if you arent getting above the stall speed.
    When I got mine done it was a night and day difference. There was no doubt it was much faster the first time I sank my foot off in it.
    Jackson, TN
    come on 24 views and only one reply? I know someone in here has a stall and can tell me if im crazy or not
    Dec 2003
    Azle,TX
    Yeah....mine feels slower too! But w/slicks i dropped 6 tenths in the 1/4
    Vortec Performance Tuned
    Mar 2005
    yeah put the stocker back in and you will be sick then it feels like a sled
    Sandy Hook, Ky.
    You gotta get a tune for your new stall. A good tuner will be able to make your new conveter lock up like it it should. It's not a tranny problem at all. Your truck probably won't pull as hard on the big end as it used to because your new converter is a little less efficient on top end than your stock converter was. I lost 21 hp on the dyno locked vs unlocked. But what you gain on the bottom end is well worth a little loss on top.
    08 ECSB 5.3 2WD TSP 224/224-581/581 112 LSA, TSP 7.4 Pushrods, Comp 918's, LS7 lifters, LS2 Valley Cover, Ported Throttle Body, MSD 8.5 wires, Yank SSTB 4000 Stall, Yukon 4:56 Gears, Stock Posi Unit, Pacesetter LT's with ORY, Made 323 RWHP, 318 RWTQ With Converter Locked Rolling on 20's, Made 302 Unlocked. Tuned by BlueCat w HP Tuners
    Slimsilverado Guest
    i got a 3k stall and it feels so much better, Nelson tune also... plus stays in the power band better after each shift....
